The higher CYA helps the chlorine stick around in your pool longer. That allows you to run with a lower output setting on the SWG. I've had one for several years with cya of 70-80 and 1-2ppm chlorine with great results. I only add bleach after very heavy rains. Hope this helps, Tony
