Results 11 to 13 of 13
Thread: Weeds and other things - Will they grow through my Pool?
    Default Re: Weeds and other things - Will they grow through my Pool?
    Quote Originally Posted by hrsdennis View Post
    To treat the ground I use a product called Pure Blue. It is a grass killer that is designed to kill nut grass and other types of growth under vinyl lined pools. It is a granule, non oil base grass killer. I prefer this type of ground treatment because I can treat the ground and install the liner the same day. With an oil base treatment a few days should pass before you can install the liner. A strong oil base grass killer can melt a vinyl liner if installed to quickly.
    I prefer installing the pool on a sand base directly over the dirt. Should your liner ever leak the water does not get trapped, it can drain into the soil. When a ground pad is used the water has no place to go. This causes squishy sand and moss quickly grows underneath the liner.
    There are times however when I strongly recommend a thick ground shield. Near by tree roots or a bad case of gophers are two examples where I would want the extra protection.
    Some unique situations are so extreme a concrete pad is the best way to go. You should spend some time picking the brains of the people in your area with pools. What’s good here may not be at all good where you are.
    Later, Dennis
    Can you tell me where to buy pure blue?
    farmgirl is offline Registered+ Thread Analyst farmgirl 0
    We sprayed with rouncup after clearing the land, but before adding sand. We did 2 days of roundup, then laid our black plastic barrier, then added sand on top of that. Might have been overkill, but better safe than sorry!
    Hertford, NC
    (about an hour west of the Outer Banks)
    24 foot round above ground
    Hi bad, I have one of my local pool stores order the product for me in 100 lb barrels. It is also available in bags from 1 to 5 lbs. Those are the normal amounts needed to treat one pool. I order from Pool Supply Wharehouse in Phx. Az. but the product comes out of Forida.
    Hope that helps some, Dennis
  1. Do these things work?
    By Bosch232 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-22-2013, 12:19 PM
  2. Can bad things happen to pool sitting empty
    By jaclan in forum --cleanup--
    Last Post: 05-25-2013, 07:50 PM
  3. Getting things ready...
    By jilted in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-09-2012, 10:25 PM
  4. Does algae grow better in warm water or in cooler water?
    By keithw in forum Dealing with Algae & Slime
    Last Post: 10-02-2006, 12:39 PM
  5. Replies: 15
    Last Post: 08-22-2006, 12:53 AM
