Results 1 to 10 of 11
Thread: Tip to add salt
    North Florida
    Thumbs up Tip to add salt
    Just added 7 bags of salt yesterday and another 2 today after my salt test showed I hadn't quite reached my target. The AquaRite should get fired up tonight .
    I really, REALLY want to thank whoever it was that had the idea of putting the salt in my big leaf basket and then hanging it over the pool's edge by a return. I wish I could remember where I picked up that idea so I could give proper credit where it's due. It was great putting in about half a bag at a time and then doing something else while it dissolved in front of a return. and, by being careful, I didn't even have to brush (much...).
    Sandy
    Morris, IL
    Default Re: Tip to add salt
    That is a good idea, I may have to add mine like that. I can't get anyone to do it for me and I am not allowed to swim yet. Hopefully Tuesday I will be allowed to get back in and I will just do it myself.
    Saint Cloud, FL
    Sandy,
    You might have got it from me. I use it to dissolve CYA. It is very effective.
    http://www.poolforum.com/pf2/showthr...=6645#post6645
    Pat
    North Florida
    Thumbs up Re: Tip to add salt
    Then thank you, thank you, as it made the chore of adding bag after bag much easier. I also know that right from the beginning, it was all dissolved!! Great idea!
    Sandy
    Whats wrong with just dumping the bag of salt in the pool and walking away while the pumps circulate the water?
    Ft Lauderdale, Fl
    Depending on the type of salt used, it may cause staining.
    This is caused mostly granular salt that contains an anti-caking additive called Yellow Prussiate of Soda (YPS). YPS has trace amounts of iron in it. Leaving this type of salt on a plaster surface can stain it.
    Solar salt and water softener (conditioning) salts do not have YPS and should be safe to add without this process of slow dissolving it. Make sure your pump is running though. It will help dissolve the salt faster, and spread the salt evenly throughout.
    I've used the granular salt without problems for years but you have to make sure you dissolve it rapidly. Fortunately, granular salt will dissolve rather quickly. I usually see about 60 - 70% of it dissolve before it hits the bottom of the pool. It's fast dissolving. What to do with the rest? If you dump the salt over the main drain, brush the rest directly into the main drain. It will be dissolved before it hits the filter! Adding it all in one spot makes it easier to brush also. Forget about walking around the perimeter of the pool while adding the salt. It just makes more work for you.
    Sean Assam
    e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
  1. Salt water system faulting high salt.
    By Skelly607 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-27-2013, 10:43 AM
  2. Aqua Rite low salt reading when salt has been tested high
    By DirtRider67 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-19-2011, 05:58 PM
  3. Salt Level Keeps High without Addition of Any Salt
    By TooSalty in forum The China Shop
    Last Post: 08-13-2011, 01:56 PM
  4. Salt in a Non-Salt Water pool
    By wollypog6 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-31-2006, 10:01 AM
