Results 1 to 3 of 3
Thread: Ec45 vs Ec40
    Default Ec45 vs Ec40
    I have an old Hayward EC45 DE filter on my pool. I was just given a less-than-perfect EC40 for parts. Looking at the two, the main basin appears to be the only difference -- the EC40 is about 6 inches shorter than the EC45. All other parts appear to be identical.
    Since it is smaller, it would look nicer if I swapped over to the EC40 basin, but I'm wondering if I'm missing something? Seems it uses the same amount of DE, has the same number & size tubes, etc, so the flow rates and capacity and such should all be the same.
    Any thoughts?
    Harry
    10,000 gal IG
    Maryland
    Rock Tavern, NY
    Default Re: Ec45 vs Ec40
    You should look them both up on the Hayward website. They have schematics for all their equipment there and the specs for them as well.
    I have an EC-65. The difference between it and say an EC-75 is the flow rate and filter size. The 75 takes a pound more DE medium and is designed for a larger pool.
    18x42 Spartan Roman End Vinyl Inground (1981)
    1HP Hayward Superpump -- Hayward Perflex EC-65 DE Filter
    I went to Hayward first. They only list the 40 and 50, and then the 65 and 75. No 45 anywhere.
  1. Hayward ec40 ac
    By green600 in forum Pool Equipment & Operations
    Last Post: 05-26-2010, 08:00 AM
