What they do is have one person hold a block of wood against the liner in the spot where the return will go (inside pool), another person drills with a hole saw from the outside - right through everything and into the wood, once they pull the hole saw off (metal and liner included), the wood is still held in place to avoid the gusher, then the return jet is placed in very quickly - if you're good, you would lose less than a bucket.
