Results 1 to 10 of 17
Thread: water level dropping
Threaded View
    Default water level dropping
    HELP! I have a new liner pool (in ground 20x40) put in last summer. I have lost about 1-2 inches a day lately and at first I thought it was lots of kids in and out, but now it seems too much. I have turned the filter off to see how low it will go this morning. I dropped a little dye around all of the inlets and skimmers, but all I had to use was food coloring and it was the gell type and too heavy I think. I didn't see any obvious sucking in of the dye, but it probably wasn't reliable. How to you do a dye test for the bottom drain and what kind of dye is the best to use. I am also leaving town for a week next Sat and am worried about how to leave it if it is not fixed.. HELP! I have loved using bleach this summer, it has been so easy!!!
  1. Dropping TA, for the workin man or woman....
    By steveinaz in forum Dealing with Alkalinity and Calcium
    Last Post: 07-11-2010, 01:04 PM
  2. vinyl IG pool, water level dropping; options?
    By AZVal in forum In-Ground Pool Construction and Repair
    Last Post: 12-18-2009, 10:34 PM
  3. Opinion RE water level dropping
    By penelopepitstop in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-03-2008, 08:52 PM
  4. PH Keeps Dropping
    By rilesworld in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-08-2007, 03:32 PM
  5. Dropping ALK questions
    By medvampire in forum Dealing with Alkalinity and Calcium
    Last Post: 07-05-2006, 03:43 AM
