Thread: Salt build up on stone and stamped concrete
    Jul 2006
    Post Salt build up on stone and stamped concrete
    How can I remove the salt build up on my stone wall for my water fall and on the stamped concrete. Without causing any damage???
    duraleigh Guest
    Default Re: Salt build up on stone and stamped concrete
    If it's salt, it should dissolve in water. If not, you probably got calcium buildup. Mild muriatic acid (usually less than 10%) will normally dissolve calcium buildup. Rinse it with clear water as soon as the calcium is gone.
  1. Salt and stone
    By aiannar974 in forum --cleanup--
    Last Post: 05-26-2013, 10:05 AM
  2. Considering stamped concrete pool deck
    By docsobeck in forum In-Ground Pool Construction and Repair
    Last Post: 06-03-2010, 10:22 PM
  3. Calcium deposits on Stamped Concrete
    By cschnurr in forum In-Ground Pool Construction and Repair
    Last Post: 02-12-2007, 06:59 PM
  4. Stamped/patterned concrete pool deck owners
    By txborn in forum In-Ground Pool Construction and Repair
    Last Post: 10-05-2006, 08:16 PM
  5. Is there a problem with salt corrosion of stone?
    By Amir in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-26-2006, 04:16 PM
