Thread: DE in pool return
    Default DE in pool return
    Hey folks,
    I've had my pool for 4 years, and have never had this problem. Every time I turn the pump on high, DE comes out the return for about 5 seconds or so, then the water clears. This is making my water cloudy and irritating me. Any thoughts? Could it be to much/not enough DE in the filter?
    Thanks!!
    Default Re: DE in pool return
    Did you recently just add DE? We added 4lbs. of DE to our skimmer when we put the pool up 3 weeks ago. I kept finding fine/white powder substance on the bottom of the pool. We would vacuum it up and then it would be back the next day. This went on for over a week but it is now finally not happening anymore. I think it was just excess DE from our initial 4lbs. we added. Maybe next year we'll only add 3.5? Good luck!
  1. New here - In ground pool return replacement
    By Pool Slave in forum In-Ground Pool Construction and Repair
    Last Post: 06-21-2012, 08:22 AM
  2. all 4 pool return ports are plugged
    By craig in forum In-Ground Pool Construction and Repair
    Last Post: 05-22-2011, 03:06 PM
  3. Air in pool return lines
    By Pool in Carolina Blue in forum Pool Equipment & Operations
    Last Post: 09-09-2006, 10:24 AM
  4. Adding a return to an AG pool.
    By esalkin in forum In-Ground Pool Construction and Repair
    Last Post: 08-16-2006, 09:39 PM
  5. How far from pool do return lines go?
    By kissinger99 in forum Pool Equipment & Operations
    Last Post: 08-10-2006, 05:05 PM
