Closed Thread
Thread: Help Size Pump and Filter and Calculating Gallon Capacity of Pool??
    Jul 2006
    Arkansas
    Default Help Size Pump and Filter and Calculating Gallon Capacity of Pool??
    The brochure states that the pool is 28,017 gallons. By the formula using average depth I get about 35,000 gal (using rectangle shape in calcs) The pool is 40'6 X 20'6" GRECIAN style or very long octagon ( 8 sides) 3 ' deep on shallow and 8' deep on deep end. Are the answers different because the pool is not a rectangle? 7,000 gals seems like a lot of difference to me. I want to select the correct pump and filter size. Would 7,000 gals make a difference? Would like to turn water over every 8-10 hours. Do I need more than 2 returns? May add a water slide and fountain in a couple years and a SWG. Any input is appreciated.
    mas985's Avatar
    Pleasanton, CA
    Default Re: Help Size Pump and Filter and Calculating Gallon Capacity of Pool??
    Quote Originally Posted by webfeet
    Yes. Also steps, benches and curves from walls to bottom reduce the volume. I would go by the brochure.
    11 GPM but again, I would just go with the brochure.
    My pool is 21,000 gallons and I have 4 returns. Do I need them? Probably not but they are nice to have. I point 1 downward in the deep end and the other three to provide proper water flow to my two skimmers. Yes it is overkill but it was what I wanted and I am glad I did it.
    Other recommendations:
    A large filter will minimize cleaning/backwashing.
    A small HP pump will minimize electrical bills. You only need 47-58 GPM for 10-8 hour turnover so a 3/4 HP high efficiency pump is all that is really needed for circulation. However, if you need more power for a spa, water features etc., then consider a two speed pump or multiple pumps. If your not going to add the water features till later, then get the pump for those features at that time.
    Mark
Closed Thread
  1. What is best pump/filter for 300 gallon kiddie pool?
    By Beverly in forum Above-Ground Pool Construction & Repair
    Last Post: 07-12-2011, 07:37 PM
  2. Filter/Pump size
    By mackeeg in forum Pool Equipment & Operations
    Last Post: 07-23-2009, 04:06 PM
  3. what size pump/filter
    By kjmelak in forum Pool Equipment & Operations
    Last Post: 05-11-2006, 11:45 PM
  4. What Size Pump And Filter
    By sisie5 in forum Pool Equipment & Operations
    Last Post: 04-17-2006, 11:15 AM
  5. Calculating optimal pump size for my system?
    By Phillbo in forum Pool Equipment & Operations
    Last Post: 04-10-2006, 01:18 PM
