Thread: Jandy stain remover
    VA, USA.
    Default Jandy stain remover
    Hi All,
    Did anybody has used the Jandy stain remover before?
    http://www.jandy.com/html/products/cleaners/stainremover.php
    I have a couple of stains in my pool which I can’t get brushed off and I was thinking to use acid to get them off the plaster. I saw the Jandy stain remover and the idea sounds good to me. I just don’t know if it really works.
    Guido
    VA, USA.
    Default Re: Jandy stain remover
    Ok I got this thing and it works pretty good after you have it all set up you just put it over the stain turn it around. The Acid flows right on top of the stain and you can see the yellow color when the Acid starts reacting.
    Well the problem is I can't get the stains of the plaster. The stains are brown and some are dark nearly black. I tried Vitamin C, Chlorine and Acid with not success. All with direct applying the stuff on to the stain.
    Does anybody has an idea what else I can try?
    Guido
    mbar's Avatar
    Ashland, PA
    If you post all of your chemistry, it will be easier to help you. Also post where you fill water came from (well, city water) and if you know if you have any metal in your water. Post:
    Free Chlorine
    Combined Chlorine
    Total Chlorine
    Ph
    Alkalinity
    Calcium
    Cya (stabalizer)
    size, (gallons) of pool, filter, and you have a plaster pool.
    Thanks, we can help you better if we can see what is going on with the water.
    Northeast PA
    VA, USA.
    Hi Marie,
    I have a 22 000 gallon plaster pool which was finished last year in November. Cartridge filter with SWG. My #’s taken with Ben’s kit are below.
    CYA 60
    PH 7.5
    TC 4
    FC 4
    CC 0
    TA 90
    Hardness 260-270
    Salt 3000 -3200
    Temperature 85
    We filled the pool from city water delivered by truck. I have never tested the water for Copper or Iron. But I can have it tetsted on the weekend.
    I noticed that the brown color of the stains look very similar to the clay which we have here in VA. So I was hoping the stains are just dirt and go away with Acid or a good brush. But they don’t. I applied the acid for around 10 to 15 sec as I don’t know how much the plaster can take.
    Thx for any hint you can give me.
    Guido
    VA, USA.
    I had the water tested for Metals over the weekend and I have 0.2 Iron in the water nothing else.
    Is this an indication that my stains are most likely organic?
    I placed a chlorine stick onto the stains for around one hour and I can’t see any changes in the color.
    mbar's Avatar
    Ashland, PA
    If all those things didn't work, then I would get in touch with the company that put in the pool - maybe something with the plaster - They would probably be able to help you out. There is also a stain kit by Jack's Magic that helps to identify stains. My opinion since your pool is new is to get in touch with the contractor and ask his opinion.
    Northeast PA
  1. CYA Remover -- is it Melamine?
    By chem geek in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 10-05-2007, 08:47 PM
  2. CYA remover?
    By steveinaz in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-11-2007, 11:04 AM
  3. Cyanuric acid remover
    By crackerjack in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-13-2006, 11:15 PM
