Thread: Solar heating in winter in Socal?
    noworries is offline ** No working email address ** noworries 0
    Jul 2006
    Default Solar heating in winter in Socal?
    I asked a pool guy about solar heating my pool--with the idea it would stay warm all year long. He said in the winter time it won't keep it heated. Does anyone in socal or a similar climate have any more info on winter performance? My pool get's plenty warm in the summertime (it's 86 now)--so if it won't heat it in winter I'll have to look at another option.
    mkelley is offline Registered+ Thread Analyst mkelley 0
    Default Re: Solar heating in winter in Socal?
    You don't say *exactly* where in S. Cal, but here are the numbers for San Diego and then lower down a link to numbers for Los Angeles:
    http://www.powermat.com/sizing.html
    I think you can see that you won't be swimming in the winter with solar alone -- drop off (even with cover) means no swimming past October. Solar will add swimming for you in the 80's from March through October (which I doubt you are getting now -- just about any pool in the country can be in the 80's during July and August <g>) so it is effective, just not a miracle cure.
    Or you can go with a heat pump -- it will cost more to operate than Solar (which is "free" once installed) won't last as long (typical life is 5-10 years versus 10-20 years for solar) but can heat your pool as long as the outside temps are above 45.
    Poughquag, New York, USA.
    Well, I lived in San Diego for years and my brother stills lives there, with a pool with solar. They swim year round, using the heater only to heat the spa, which spills into the pool. I would guess that you could easily swim into late november with 100% solar alone (assuming good S, SW placement) and probably longer if you had more. If you covered every night, I am pretty sure you could maintain your pool in the 70's year round with 100% coverage.
    I currently live in NY, and we were able to heat our pool into the 80's into late October last year (until we had 2 straight weeks of rain, then we packed it in). And we opened in early April and had it to 85 within weeks. That is with about 55% coverage.
    So, I would say you could swim 9 months or so a year comfortably in San Diego with 100% coverage. LA too. Further north, not sure.
    Ventura County, California.
    Jul 2006
    Can you run a heat pump off 110? My problem is running 220 or gas to where my pool equipment is would be very expensive.
  1. Heliocol vs. Solar Industries for solar heating
    By KevinSDiego in forum Pool Equipment & Operations
    Last Post: 06-07-2012, 04:22 PM
  2. Solar Heating
    By badutahboy in forum Above-Ground Pool Construction & Repair
    Last Post: 04-08-2007, 12:38 PM
  3. Solar Heating Question
    By mohawk in forum Above-Ground Pool Construction & Repair
    Last Post: 02-16-2007, 07:43 AM
  4. Solar cover worth it in Socal?
    By noworries in forum Pool Equipment & Operations
    Last Post: 08-21-2006, 10:01 PM
  5. Solar Heating
    By AprilRose in forum In-Ground Pool Construction and Repair
    Last Post: 04-22-2006, 02:41 PM
