Will that work in a vinyl pool? I have read they are only for gunite. I am willing to spend more if it will last and work well.
I got one of the smaller ones from Ben a couple of weeks ago. If you're tired of the cheap stuff that is made for "selling" instead of made for "cleaning" then this is the best thing I've ever seen. The whole base flexes so when you move around the bottom of the pool's curves, it hugs the bottom. The attachment for the pole is metal, not plastic, and it steers. That is when you twist the pole the head stays flat on the pool bottom and changes direction.
I have one of the ones pictured above and this thing is wonderful by comparison. I have not timed it but I can tell you it is much much faster, largely because you can steer it.
PS my pool is IG liner.
I went to Leslies today for a new vac head. They only had the half moon shaped one and a triangle. The triangle was made of blue plastic that you can not see through. I was not to happy. I looked to my right and there was a replacement nech for the vac heads. I bought that and am using my old see through vac head.
Thanks for all your replies, suggestions and help,
Brian
