Well I went and finished my equipment upgrade today. As some of you may recall I slowly upgraded all my equip to Hayward filter, pump, skimmer, return, 1.5 inch hoses and a new liner on my AG pool. What a great experience it has been this year, no problems and much more time to swim. Anyway the last thing, or so I thought, to upgrade was my vac hose. I went out today and bought a 25 foot 1.5 inch vac hose and new 12 foot pole. I had a vac head in my hand but at 30 dollars and looking exactly like the one I have I put it back. I came home and installed the new pole on the vac head and you guessed it, the damb vac head breaks. The hinged neck that slides into the pole cracked in half. So now I need a new vac head. I want to buy a good one so I will not have any problems. I am sick and tired of the cheap discount garbage out there. Any suggestions about a vac head for a vinyl liner pool?
Thanks,
Brian
I am not thrilled with triangle ones but atleast I can see through the plastic and know if the leaf was sucked in or not. The concesus appears to be move slow, very slow or all the debris floats away. I too "twist" the handle to get the larger debris under the head so it doesn't just push around. I will check out a few places and see if I can come up with anything else. If I do I will post back, if not then I am getting the triangle unit.
