We have an inground pool with a vinyl liner. It is leaking a lot but not sure from where. We just replaced the pump because the last one was cracked. (I don't think the landlords closed it properly last winter.) We are getting a lot of air in the pump when we use the bottom drain. Is it possible one of the pipes underground are cracked and causing the air and the water leak? How would we know for sure? If the landlord hires someone to fix it how should it be done and about about how much should it cost? (All this is assuming it is the pipes to the bottom drain.)
Thanks,
Amanda
