Thread: SAm and SAL lights and voltage level
    Default Re: SAm and SAL lights and voltage level
    actually, both the 120v and the 12v units have 12v bulbs. The 120v units have a transformer in the light housing while the 12v units use an exernal transformer so the power going into the pool is 12v.
    Sugar Land, Texas
    I'm weak in the electrical area, but that would suggest to me that the 120V would be preferred. Correct?
    Quote Originally Posted by eljefe281
    Not my strong point but I would personally rather have 12v going into my pool than 120v. I think the difference would be in how long the electrical run needs to be. 120v might be necessary for a long run. (and you don't have the added expense of the Intermatic transformers for each light).
    mkelley is offline Registered+ Thread Analyst mkelley 0
    I have no idea about the voltage, but we have both the SAM and SAL lights and like them a lot (particularly how we can control the color from our Aqualink inside).
    Actually, I have SAM, SAL and a PG2000 fiber optics illuminator in my pool/spa now. My builder has finally gotten around to finishing things and repairing the damage he did and has replaced the FiberStars uinits with the Pentair ones. From what I have seen I like them (The colors are more pastel then the FiberStars units and the color wheels turn slower...a more pleasing and relaxing effect)
  1. adding fiber optic lights to existing pool/spa lights
    By jjjjj in forum Pool Equipment & Operations
    Last Post: 07-06-2012, 11:30 PM
  2. aqua-rite cell voltage
    By Harley91 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 01-16-2009, 01:37 PM
  3. External Pool Spot Lights - High Voltage or Low Voltage?
    By CJDahl in forum In-Ground Pool Construction and Repair
    Last Post: 01-16-2007, 09:31 PM
  4. Pool / Spa Light Voltage
    By gordonhyde in forum In-Ground Pool Construction and Repair
    Last Post: 10-08-2006, 12:51 PM
  5. Pump voltage
    By medvampire in forum Above-Ground Pool Construction & Repair
    Last Post: 06-14-2006, 11:32 PM
