Results 11 to 20 of 28
Thread: Electrical costs for my pool
    Default Re: Electrical costs for my pool
    my electric meter gives the reading for KWhrs but I have so much stuff going on generally it wouldn't be very practical to try and shut everything down and monitor the pool pump or AC. Currently we are using about 100 KWhrs a day, my last electric bill was $811 a personal record
    IL.
    Based on the estimated cost arrived at above, my pump accounts for 34% of my electric bill.
    Timer here we come
    Houston.
    Wow. Glad I posted a popular topic. I wasn't aware of the Power Factor. And it sounds like I need to do some more research on calculating motor costs.
    I've found several articles on the web to read, but alas, my work is calling me... In addition to the PF number, there also seems to be a .00173 number that is also being thrown in. This was used to calculate kVA. Siting from http://www.cop.com/SEUhtmDOCS/SEU17.htm, the formulas are:
    kVA = 0.00173 * V * amps
    kw = kVA * PF * .01 (PF being % between 1-100)
    running for one hour would be kwh and then multiply by number of hours times cost per kwh.
    Now, looking at the calculations above and the linked site, they are using the stated amps on the nameplate, where I am using the measured amps on my amp meter. It looks like the only place they're using the measured amps is to help calculate the PF.
    So what is the 0.00173 number? If I throw in the .00173 number and a 90% power factor, I'm actually increasing my kwh because the .00173 increases more than the .9 decreases it.
    Robert
    22K gallon, IG, gunite, Sunstone Pearl White Pearl plaster, Aqualogic SWCG, Hayward Tristar pool pump, Pentair Whisperflo waterfall pump, Pentair Clean & Clear 320 cartridge filter, Sta-Rite heater.
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by rpoldervaart
    This is for a 3 phase motor. Standard motors are kVA = 0.001 * V * amps
    Robert
    See comment above.
    Also, to make it simple, kwh = Volts * Amps / 1000 * (PF%/100)
    Mark
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by JohnInSoCal
    Thats why you measure it with the pump on and then off and take the difference. That way it does not matter how much stuff you have on.
    Mark
    Houston.
    OK. So I've added Power Factor to my spreadsheet as a changeable parameter. This is probably pretty close, and I'll try to get out and count the meter spins to verify soon.
    http://home.houston.rr.com/poldervaa...the%20pool.xls
    Thanks,
    Robert
    North Texas
    The Intelliflo provides actual flow and watts consumed data to produce that flow . So if you have a restrictive system the flow per watt is lower. If I could figure out a way to have enough back pressure to run the Trio Pure and cleaner and keep the flow low I could clean my pool on 440 watts hr x 14 hrs a day. or 6.1 total amps a day.
    The cool aspect is the pump will calculate the optimal flow per # of turn over per day for you if you do not use preset flow rates.
  1. repainting pool costs??
    By fhorta in forum In-Ground Pool Construction and Repair
    Last Post: 07-18-2014, 04:48 PM
  2. New pool owner getting frustrated with costs
    By jaff50 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-22-2012, 08:32 PM
  3. Repair Costs for IG Pool???
    By newbie2pools in forum In-Ground Pool Construction and Repair
    Last Post: 09-17-2008, 11:17 PM
  4. DIY Pool Construction Costs
    By Blinger in forum In-Ground Pool Construction and Repair
    Last Post: 06-22-2006, 08:06 PM
