Results 11 to 17 of 17
Thread: CYA not showing yet.
    Tennessee
    Default Re: CYA not showing yet.
    If you have any CYA that you put in you could take pool sample and desolve a small amount of CYA in it and test to see if it is any good.
    Heartland
    That sounds like a good idea. I'll tell you, I sure don't like burning off 1.42 gallons of bleach everyday.
    Central Texas
    I put 3 pounds of the Walmart (HTH brand) CYA in our pool which was supposed to add 25ppm per the BleachCalc. I'd already used two 3" pucks, which added about 5ppm CYA. So the -calculated- amount of CYA added was 30ppm. Walmart (HTH brand) 6-way test kit two weeks later said zero CYA. Pool store test said 40ppm CYA. I think the HTH test for CYA is not accurate. Either that, or their CYA is not the real deal.
    Heartland
    I'm using the Taylor K-2006C kit I bought about a month ago. I feel like the test is accurate because I can see all the chlorine burning off comparing the two tests I do each day. I was hoping to start seeing less and less chlorine burning off, that would be an indication that my CYA levels are rising. No luck yet.
    Heartland
    Well I got home today and my FC was 2.5 All the other days it's been 1-1.5
    CYA is still 0. Do you think the CYA is taking effect or is the FC difference just coincidence?
  6. #16
    Central Alabama
    No expert here but your test kit from Wal-mart (I have one too) has a quirk and the Taylor might be similar. Make sure when you are testing for cya that you allow the solution to sit for a while (I let it sit 10 minutes) before putting it in the black dot tube. I lost a lot of stabilizer reagent before I realized the recommended 2 minutes was not adequate. This may not be your problem but I had a similar experience as you before being a little more patient with the test. Hope this helps.
  7. #17
    Heartland
    I'll give waiting longer for the solution to develop a try tonight. Taylor's instructions say to wait 30 seconds. I noticed my afternoon CL reading was higher yesterday, so something inside me says the CYA is there. We'll see. I'll post tonight what happens after I wait a longer amount of time. Thanks.
  1. Pool pump showing a high psi
    By Wakkoguy in forum Pool Equipment & Operations
    Last Post: 07-18-2012, 12:54 AM
  2. No Chlorine showing up!!
    By Preston in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-28-2012, 07:13 PM
  3. Chlorine Not Showing Up...
    By tommypenngotti in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-01-2009, 05:20 PM
  4. Still showing no cya
    By tjcat in forum DPD-FAS based testing
    Last Post: 07-02-2006, 05:41 PM
  5. Help! 911 - algae showing up
    By sw_stupid in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-23-2006, 08:44 PM
