Hello,
I got an AG pool last summer - beaded liner. When taking winter cover off - a small portion of liner had popped off - we put it back on. Sunday, all of a sudden, the liner popped off big time - all the water gushed out.
sand washing away around sides. We have redone the places where sand washed (concrete filler stuff??) anyway...I am switching to a overlap liner as I keep hearing there are less problems (true or false????) - many theories on why this happened - don't know if liner type will make a difference - we are working on correcting a water drainage problem on hill behind pool in case that was a cause. One pool place said that the beaded liner probably shrunk from heat - but that doesn't make sense to me. And if that's the case, why wouldn't a overlap do the same - then I would end up with a hole instead of popping off - but would I end up with the same water gushing disaster???
HELP!!!!!!!
