Results 1 to 10 of 21
Thread: Too much suction !!
    mas985's Avatar
    Pleasanton, CA
    Default Re: Too much suction !!
    There is only one condition where this can be true and that is with a 2 speed pump. Going from low to high speed, you are effectively changing the HP of the pump so you will see both a rise in PSI as well as suction.
    Assuming the same pump and speed, and the PSI rise is due to a dirty filter, solar or other return restriction, higher filter pressure = more head loss which means less GPM. Less GPM = less suction. This what hydraulic theory dictates and what I have confirmed through measurements.
    If you had a suction guage on your pump, you would see it drop with higher filter PSI. However, just the opposite happens when the PSI drops so perhaps this is what you are experiencing.
    Mark
    Jul 2006
    Ok guys ---thanks for all the input but honestely we do have too much suction. Hubby actually bent the pole trying to get the head unstuck. Also you are talking to a real dummy here. As you can guess this is our first season of maintaing our pool on our own so we have lots to learn and we sure do appreciate your help.The pump is an AquaTool Sand filter,Stay -rite
    dyna Glass with RPM of 3450- tank says 300lbs. I have no idea about what I just wrote--that is just what it says on the tank. Thought maybe it might help you guys.
    To vacuum we put this black disc in the skimmer and attach the hose filling it with water. The head is attached at the end of the hose that we put in the pool. Keep water pressure about 15--if it starts to rise we backwash. The only thing we have not been doing is rinsing MAYBE that is the problem!! Could the sand be too dirty? Water is dirty when backwash but clears right up in few min. Should I be rinsing after I backwash??
    Duraleigh you suggested restricting the ball valves on the pressure side of the pump---How do you do this (told you I was a dummy)
    Please keep the suggestions going--ALL help is appreciated
    Karen
    duraleigh Guest
    Karen,
    You should have a valve/valves on the pipes that come out of your filter and take the water back to the pool. If you partially close that/those valves, your pressure will rise on your guage and you will have less flow throughout the entire system....that means less suction.
    I'd stop closing the valve when the pressure got to 25...maybe 28 max.
    Virginia Beach, VA
    With some of the pool owner's manuals I've read, if the vac head gets stuck on the bottom, it is recommended to shut off the pump. That should take care of any pole bending problems when trying to free the vac head.
    A few questions.
    Does your pool have a main drain?
    Does your pool have 1 or 2 skimmer's?
    What type of in ground pool is it? (Gunnite, Plaster, Vinyl, Tile, etc.)
    Neil
    Mandeville, LA, USA.
    Karen,
    Do you have a main drain on your pool? If so, have you closed the valve on that pipe thereby diverting all the suction to the skimmer? Is is possible that your main drain has something on it or in the pipe that is keeping you from getting suction there?
    Jul 2006
    Thanks everyone for your input.
    Answers to questions: I really dont know if we have a main drain or not. Where might it be located? When we partially drained the pool -- just used a small pump.
    Only have one skimmer
    I have been told the pool is gunnite.
    Boughr a new head at walmarts today--going to try that tomorrow
    Again thanks
    Karen
    Quote Originally Posted by karenkr
    In the bottom of the pool.
    Again thanks
    Karen
    Is there a valve or valves on the pipes the go into the suction side of the pump (the side that has the pump strainer on it)?
    Jul 2006
    I had similar problem last year. the brushes on the bottom of the vacumn head were worn down. once i replaced the brushes no more sticking.
    karen,i find i can lose prime while vacuuming if 2 things occur:
    a)my main valve is closed (so water is only going through the skimmer and hence the vacuum..so if the vacuum, or vacuum line is plugged,you lose prime) you can leave your main valvel completely open or partially if it decreases your vacuum suction too much and that way you won't lose the prime.
    b) if my basket in the pump itself is full of gunk. in which case, obviously doesn't matter which valves you have open and closed or how much given it's one line going into and out of the pump!
    check both of those things out. at start of season is when i tend to lose prime because the bloody basket keeps filling up with muck from the winter (leaves, sediment,little twigs,etc..hence why i'm buying a leaf cover for the fall)
    Jul 2006
    Will check both those things.
    Will just keep watch on prime to make sure does not go completely dry.
    Sure appreciate all your help
    Karen
  1. Poor Skimmer Suction and Good Main drain suction
    By teachone in forum In-Ground Pool Construction and Repair
    Last Post: 06-14-2012, 02:06 PM
  2. Suction
    By Rkh3 in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-18-2011, 09:35 PM
  3. Suction, Where did it go?
    By Orkalovesfood in forum Pool Equipment & Operations
    Last Post: 08-07-2006, 06:25 PM
  4. No suction from pump
    By butlercns in forum Pool Equipment & Operations
    Last Post: 08-04-2006, 11:35 AM
