Closed Thread
Results 1 to 10 of 10
Thread: pool newbie with new sand filter questtions
    rnjng Guest
    Question pool newbie with new sand filter questtions
    Just purchased a new hayward 256t 250# sand filter. 1st ques. The old filter had 1 1/4" fittings and hoses. the new filter has 1 1/2" hoses and fittings. Do I need to chage all fittings and hoses to 1 1/2" so they are all uniform? Next ques. is the valve clamp on the filter supposed to be completely clamped together when you tighten the screws, or can you leave alittle gap. I'm nervous on closing the gap, that is how the old filter clamp broke.
    rnjng Guest
    Default Re: pool newbie with new sand filter questtions
    Just wondering if anyone has any input on this situation.
    Morris, IL
    What do you mean? The stainless steel hose clamp? This does not have to be completely together at all, just tighten it until it feels tight, generally it will start to want to twist rather than tighten, stop at that point.
    drumr is offline ** No working email address ** Thread Analyst drumr 0
    Gordonsville, Tn.
    rnjng,
    you can change your hoses to 1 1/2" if you want too which would probably be the best thing to do to get the most flow with the least amount of resistance. Or you can get step down adapters from your local hardware store that step down from 1 1/2" to 1 1/4" and use the same hoses you already have. I don't know if it would make that big of a difference. Either way I believe you will be fine.
    As far as the valve clamp goes, just make sure when you get the clamp snug that you tighten each side a little at a time alternating between the 2 screws, you can probably leave a little gap between the clamps, if it leaks you can always tighten a little bit more until it doesn't leak any more.
    Morris, IL
    The light went on, I know what clamp he is talking about now. lol. Yes, do that, alternate until it is snug, there is an oring there that makes the seal right, all the clamp does it tell it to stay put.
    rnjng Guest
    SWEET!!! THNKS! One more thing, Like I said this is a new filter, do I let the pump fill the filter qith water, or do I need to fill the filter with water befor I put the valve on?
    Honesdale PA
    The pump will fill the filter and any trapped air will bleed out. Tighten up everything and fire the pump. May take several minutes for the air to escape but that is normal.
    rnjng Guest
    really quick... I was looking at the fitting on the pool, and the valve to change between skimmer and main drain. I noticed that the fittings are or look like they can be 2 sizes. Currebtly and prior to new filter I has 1 1/4" hoses. The fittings that are on seem to be both 1 1/2" and 1 1/4". They look like step downs. Can I just cut the end off of the fitting and make it 1 1/2"?
    yes - I was just told by the system that I need to put at least 10 characters in here, so yes yes yes!
    rnjng Guest
    Thumbs up Re: pool newbie with new sand filter questtions
    maybe i'll have the pool ready before closing time. LOL
Closed Thread
  1. Sand Filter dumped all the sand in my pool
    By ib_gman in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-15-2012, 01:16 AM
  2. newbie. Our first pool, Need info on sand filter
    By rnjng in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 07-07-2006, 03:39 PM
  3. Sand in bottom of pool from sand filter
    Last Post: 06-20-2006, 01:01 PM
  4. Jacuzzi ST-24 sand filter - sand in pool
    By ksturge in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 09:58 AM
  5. Newbie pump/sand filter AIR question
    By famdog in forum Pool Equipment & Operations
    Last Post: 06-01-2006, 10:20 AM
