Results 1 to 10 of 59
Thread: White Cloudy Water - Twighlight Zone
    Mandeville, LA, USA.
    Default Re: White Cloudy Water - Twighlight Zone
    It sounds like you're in the homestretch. Keep it at shock level until it maintains the FC level overnight and then keep the FC between the Best Guess table min and max for your CYA level.
    You probably already know this but regular old 20 Mule Team Borax is a much cheaper substitute for pH Up.
    Congratulations on getting your water cleared up.
    szampino is offline Registered+ Thread Analyst szampino 0
    I can honestly say I could have never gotten this far if it wasn't from the constant support and help from this forum!
    Thank you to everyone who helped me get to this point!
    Revived POP
    Intex Blow-up Ring 18x48 round
    Cartridge Filter
    gerri is offline Registered+ Thread Analyst gerri 0
    Jul 2006
    Upstate, SC
    You're in the home stretch now! Woo-hoo! Keep that Chlorine up and you're home free.
  1. White cloudy water
    By bb158 in forum Dealing with Algae & Slime
    Last Post: 06-07-2013, 09:16 AM
  2. White Cloudy water
    By billbeard78 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-07-2012, 09:49 PM
  3. White cloudy water
    By PoolParadise in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-21-2011, 12:09 PM
  4. White foam on cloudy water
    By crsuarez in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-06-2007, 04:59 PM
