These are my results that were taken this morning.
AG-18400 gal with SWC
FC=4
CC=1
TC=3
PH=7.5
ALK=100
CYA=40
Temp 89
Just added salt yesterday and got pool pilot turned on.
Would appreciate comments from here. How are my readings?
Thanks,
Keith
FC=4
CC=1
TC=3
PH=7.5
ALK=100
CYA=40
Temp 89
Thanks,
Keith
Keith,
If your water is sparkling, I'd say you're in fairly good shape.
If not, then I'd shock (up to about 15-17ppm) with bleach and get Combined Chloramines (CC's) out of your pool.
I'd shock now if it were my pool but, certainly, if the CC's ever test greater than 1.0.
My water is sparkley,How do I get the cc out?
Poorly worded sentence....sorry. Should've written:If not, then I'd shock (up to about 15-17ppm) with bleach and get Combined Chloramines (CC's) out of your pool.....TO get Combined Chloramines (CC's) out of your pool.
thanks dave, will add chlorine after test to determine how much to add by using the bleach cal. How long should I keep the shock level up to 15ppm and how often should I recheck the cc? thanks
Based on your good pool conditions, I would raise Cl to 15 or so ppm after the Sun is off the pool. The next AM, test again..... your Cl will probably have dropped noticeably and the CC should be zero.
If so, let your Cl drift back down into the maintenance range (3-6ppm) on it's own.
PS - don't be concerned if you still show .5 CC.....that seems to be somewhat normal and I wouldn't worry. My bet is you'll be at zero, however.
Another thing, check your numbers. If your FC is 4 and CC is 1, than your TC is 5
