Thread: My test results
    Keokuk, Iowa, United States.
    Default My test results
    These are my results that were taken this morning.
    AG-18400 gal with SWC
    FC=4
    CC=1
    TC=3
    PH=7.5
    ALK=100
    CYA=40
    Temp 89
    Just added salt yesterday and got pool pilot turned on.
    Would appreciate comments from here. How are my readings?
    Thanks,
    Keith
    duraleigh Guest
    Default Re: My test results
    Keith,
    If your water is sparkling, I'd say you're in fairly good shape.
    If not, then I'd shock (up to about 15-17ppm) with bleach and get Combined Chloramines (CC's) out of your pool.
    I'd shock now if it were my pool but, certainly, if the CC's ever test greater than 1.0.
    My water is sparkley,How do I get the cc out?
    duraleigh Guest
    Poorly worded sentence....sorry. Should've written:
    ....TO get Combined Chloramines (CC's) out of your pool.
    thanks dave, will add chlorine after test to determine how much to add by using the bleach cal. How long should I keep the shock level up to 15ppm and how often should I recheck the cc? thanks
    duraleigh Guest
    Based on your good pool conditions, I would raise Cl to 15 or so ppm after the Sun is off the pool. The next AM, test again..... your Cl will probably have dropped noticeably and the CC should be zero.
    If so, let your Cl drift back down into the maintenance range (3-6ppm) on it's own.
    PS - don't be concerned if you still show .5 CC.....that seems to be somewhat normal and I wouldn't worry. My bet is you'll be at zero, however.
    La Jolla, CA
    Another thing, check your numbers. If your FC is 4 and CC is 1, than your TC is 5
  1. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  2. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
  3. First test results
    By poolbee in forum DPD-FAS based testing
    Last Post: 06-15-2006, 11:27 PM
  4. First Test Results
    By Cutter in forum DPD-FAS based testing
    Last Post: 06-14-2006, 08:30 PM
  5. first test results
    By jazzbone in forum DPD-FAS based testing
    Last Post: 05-26-2006, 04:19 PM
