Thread: Cyanuric Acid
    Default Cyanuric Acid
    I have a 1700 Gal pop up pool and have been using the store method with success...I Think.
    I am using bleach to shock and bring up the chlorine level as needed and a mini floatie with a puck cut in half.
    I add algaecide (1tsp) & Borax(2cup) 1x week
    I have not added any baking soda. Is this why my CYA is reading low??
    Should i be using the puck? or just stick with bleach daily?
    THX
    Indiana.
    Default Re: Cyanuric Acid
    CYA is cyanuric acid, which is also known as stabilizer. You'd have to buy it at a pool store, or some Walmarts etc.. Baking soda raises alkalinity.
    Default Re: Cyanuric Acid vs. Borax
    Quote Originally Posted by JohnT
    And Borax does what?
    duraleigh Guest
    Raises pH.
    You'll find the answers to most of these things by reading the stickies posted at the top of each forum.
    prh129 is offline Lifetime Member Widget Weaver prh129 0
    Rehoboth, MA
    Borax raises your pH. Baking soda will raise your alkalinity.
    Also, I would say if you are keeping your chlorine level where it should be I would not use the algaecide. If you have to use one, then make sure it's polyquat - which is 60% dimethyl ethyl yada yada, otherwise you could end up with foaming.
    Peter
    La Jolla, CA
    Post all of your numbers and we can help better.
    What is your CYA level? Based on that measurment will determine whether you can still use your pucks (trichlor) which contain CYA (stabilizer)
  1. No Cyanuric Acid?
    By Strongmad in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-28-2012, 12:21 PM
  2. Can't get cyanuric acid to register
    By rickwray in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-21-2011, 09:58 AM
  3. Cyanuric Acid
    By Sue225 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-30-2010, 05:35 PM
  4. cyanuric acid
    By kickurasin in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-08-2007, 12:23 PM
  5. where to get cyanuric acid?
    By fog80 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-07-2006, 10:22 PM
