Help!!!
I have a 16x32 inground vinyl liner my latest readings:
24,000 gallons
FC: 5
Total Chlorine: 3
Ph: 6.8
TA: 120
Hardness: 100
Over the past 2 days i have added 10lbs of PH Up (5 lbs Borax and 5 lbs of PH from pool store) but my PH has not moved. the water clear
Re: Help!!!
Put in more Borax....it'll come up. You were probably lower than 6.8 to start.
Re: Help!!!
Putting more borax in is correct, but you numbers are a bit off, so I question your pH
You said your Free Chlorine is 5 and your total is 3.
This cannot be possible.
The total chlorine is the combination of free chlorine and combined chlorine.
So FC can = TC but never be less than it.
Make sense??
Andy
Re: Help!!!
Andy,
His/her FC result if from the FAS/DPD test and his/her TC result is from the OTO test. It is common for new posters to post both results until they recognize how each test is used.
- You may not post replies
- You may not edit your posts
Forum Rules
