Hi
I lost my chlorine calculator. Can someone email me one. I need the one that is an excel file. Not the .exe program.
Andy
azimmer1@san.rr.com
Hi
Andy
azimmer1@san.rr.com
You can probably build one - one gallon of 6% chlorine increases the chlorine level 6ppm for every 10,000 gallons. I haven't seen one in excel that is already made.
Completed 8/21/06
Spa with spillway
250K BTU gas heater (for spa)
SWCG - Aqua Rite
There was one floating around here before the system crashed!!! I used it many times. MSmith had one too, but his is a .exe program. I use a mac so I cannot install it.
I have one that I made. I'll try and get it to you tomorrow.
I actually found it on an old hardrive. Mikes program is great for a pc, but if you have a mac, this works great. Just change the values for pool size.
If anyone want its, let me know and I will e mail it to you. I cannot attach that type of file. This was a common calculator here a couple of years ago
I am trying to attach a compressed version of the calculator
Andy
I like the one I made because you can enter values, print and keep by pool supplies. It lists in a spreadsheet how much each quart raises chlorine ppm.
I just check the water, refer to sheet, add appropriate amount to bring up to level I want.
gg
I deleted this attached file because I simplified the spreadsheet, see new attachment at new post below.
Those are both nice, I like goose's better for simplicity, the other one has alot of stuff I don't need, but still well done. I will be distributing this to my pool care people.
I tuned up the spreadsheet a little take a look, much cleaner and easier to use.
Only change your pool gallons and the Bleach %
For those of you with larger pools you can still change the Bleach gallon quantity in column B.
gg
The numbers were set for my pool which is only 1500 gal
(endless pool)
All you have to do is enter your pool size.
Andy
I tried to open this file but cant.not sure why,so can someone seen it to me
email,I have troble openening zip files
thanks
