Results 1 to 10 of 11
Thread: chlorine calculator
    La Jolla, CA
    Default chlorine calculator
    Hi
    I lost my chlorine calculator. Can someone email me one. I need the one that is an excel file. Not the .exe program.
    Andy
    azimmer1@san.rr.com
    Sanford, FL
    Default Re: chlorine calculator
    You can probably build one - one gallon of 6% chlorine increases the chlorine level 6ppm for every 10,000 gallons. I haven't seen one in excel that is already made.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    La Jolla, CA
    There was one floating around here before the system crashed!!! I used it many times. MSmith had one too, but his is a .exe program. I use a mac so I cannot install it.
    I have one that I made. I'll try and get it to you tomorrow.
    La Jolla, CA
    I actually found it on an old hardrive. Mikes program is great for a pc, but if you have a mac, this works great. Just change the values for pool size.
    If anyone want its, let me know and I will e mail it to you. I cannot attach that type of file. This was a common calculator here a couple of years ago
    I am trying to attach a compressed version of the calculator
    Andy
    I like the one I made because you can enter values, print and keep by pool supplies. It lists in a spreadsheet how much each quart raises chlorine ppm.
    I just check the water, refer to sheet, add appropriate amount to bring up to level I want.
    gg
    I deleted this attached file because I simplified the spreadsheet, see new attachment at new post below.
    Morris, IL
    Those are both nice, I like goose's better for simplicity, the other one has alot of stuff I don't need, but still well done. I will be distributing this to my pool care people.
    I tuned up the spreadsheet a little take a look, much cleaner and easier to use.
    Only change your pool gallons and the Bleach %
    For those of you with larger pools you can still change the Bleach gallon quantity in column B.
    gg
    La Jolla, CA
    The numbers were set for my pool which is only 1500 gal
    (endless pool)
    All you have to do is enter your pool size.
    Andy
    sisie5 is offline Registered+ Thread Analyst sisie5 0
    franklin, in, us.
    I tried to open this file but cant.not sure why,so can someone seen it to me
    email,I have troble openening zip files
    thanks
  1. Chlorine/bleach in calculator
    By dansdad in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-09-2013, 10:03 PM
  2. Link to chlorine calculator
    By BigScott in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-08-2011, 03:38 AM
  3. Bleach Calculator
    By PatL34 in forum General Interest
    Last Post: 05-19-2006, 10:17 PM
  4. SI calculator
    By p.p.h. in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-26-2006, 01:08 PM
