Thread: Got my kit - 1st test results
    duraleigh Guest
    Default Re: Got my kit - 1st test results
    Pretty good numbers (as long as you get your pH and Alk up) but your CYA will not come down....it'll only stabilize.
    Columbus, OH
    Thanks. Didn't know if Cya moved much or not. Had none when we opened a couple months ago. Lots of crud and cloudy water. Hoping to avoid that mess for next year. pH should be ok by morning then I'll start making small adjustments to Alk.
    Thanks again
    24,000 gal IG vinyl / 1.5 HP / sand filter
  1. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 03:27 PM
  2. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 01:48 PM
  3. First test results
    By poolbee in forum DPD-FAS based testing
    Last Post: 06-15-2006, 10:27 PM
  4. First Test Results
    By Cutter in forum DPD-FAS based testing
    Last Post: 06-14-2006, 07:30 PM
  5. first test results
    By jazzbone in forum DPD-FAS based testing
    Last Post: 05-26-2006, 03:19 PM
