Thread: Best Guess Chart
    Newburyport, Ma, USA.
    Smile Best Guess Chart
    I can't seem to find Ben's best guess chemical level chart for the correct levels based on CYA etc.
    Any help would be great
    Scottsdale, Arizona
    Default Re: Best Guess Chart
    http://www.poolforum.com/pf2/showthread.php?t=365
    it's a sticky in the Chlorine section .
    Thanks,
    Yet I thought there was one that showed all the other Chemical levels as well. Like AKl, PH
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    Nope. Every pool is different so what works for one that's at one end of "normal" might not work at all for another pool that (for one reason or another) likes things at the other end of "normal". Several of us have made up our own "charts" for our own pools by reading through the PoolSolutions web site and using various info from this forum. But no one has made a chart for all pools.
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
    Thanks Sherra,
    My water is clear so I will not over think it. Yet my Alk is very low so I will bring it up slowly w/ baking soda & test again as suggested here.
    Thanks Again
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by cav
    Thanks,
    Here are some general guidelines for the others.
    http://www.poolforum.com/pf2/showthread.php?t=1113
    Mark
  1. Help with best guess chart
    By tim665214 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-09-2012, 09:10 AM
  2. Best Guess Chlorine Chart
    By PoolDoc in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 03-26-2011, 12:50 PM
  3. Best guess CYA chart question
    By fishandfly in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-19-2008, 09:24 PM
  4. Best Guess CYA chart
    By Watermom in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-08-2006, 11:25 AM
