Results 1 to 10 of 11
Thread: Do I have metal problems?
    mbar's Avatar
    Ashland, PA
    Default Re: Do I have metal problems?
    As long as you put enough sequestering agent in the water, and bring your ph down to 7 - 7.2, you should not get any more staining out of the water. It is important to put in enough sequesterant - more than what it says on the bottle, according to the amount of water in the pool. I think just by using enough sequesterant and lowering the ph, it should take the stains away, since there isn't any on the vinyl liner. After you see the stains lighten, I would take the chlorine up to shock, very slowly, about 2 ppms at a time. The chlorine should help break the "stuff" down, so it can filter out. You can also put a trichlor puck in the skimmer basket if you have a sand or DE filter. Another good idea is to get a skimmer sock, or cut the leg off pantyhose or tights - put the foot in the basket and leg around the basket. It will help to catch the really fine sediment. Hope this helps, keep us informed.
    Northeast PA
    There is a reason the pool store did not find metals in your water. It has already stained and precipitated out as sediment. Get as much of the sediment out of the pool before treating the stains in case it is iron oxide otherwise it will redissolve in the water.
    N.E. TX
    That makes sense. I guess I could have them check my fill water, but I know it's metallic b/c the Vit C test. Anyway, I guess I will try and clear up the water (which now looks like a pond) first and then address my stains. Could the pool store lady be right? - change my sand every 2-3 years?. It just seems like the sand would continue to filter if you keep it backwashed.
    Thanks again to the forum.
    27,000 IG Vinyl
    Aquarite SWG
    Still Learning Everyday
    mbar's Avatar
    Ashland, PA
    You don't need to change your sand. The only reason to change sand is if it isn't filtering - because it is gummed up. To clear your water, you will need to put in sequestering agent - more is better than not enough, keep your ph at 7.0, raise your chlorine to shock levels according to the "best guess chart", run your filter 24/7 - backwash and brush, you can also put a skimmer sock on the skimmer basket to help catch small particles - if you still have sediment in the water you may want to vacuum to waste.
    Northeast PA
    Quote Originally Posted by sw_stupid
    As far as changing the sand...it is possible that metals have deposited on the sand as 'stain'. If they have they can redissolve in the water given the right conditions. I would inspect the sand and look for evidence of staining. If there is a lot of it I would change the sand..otherwise I wouldn't. A commercial sand cleaner might also be an option to remove the metal stain from the sand if it is present. IF the metal has stained the filter material it is a good thing...it mean that you can actually remove them from the pool easily! Ideally, you want the metals to stain the filter and not the pool for this reason.
  1. Metal Stains ?
    By gfritz1 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 09-16-2012, 02:32 PM
  2. Metal Stains
    By Terry_Hope in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-14-2011, 08:11 PM
  3. have a little metal what to do
    By gone01 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-15-2011, 07:15 PM
  4. Re-occuring Metal Problems
    By toddmac in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-24-2007, 03:16 PM
  5. Pro Team Metal Magic Problems
    By derrikm in forum Dealing with Alkalinity and Calcium
    Last Post: 09-02-2006, 10:33 AM
