Closed Thread
Thread: Adding a IG spa to an IG pool
    noworries is offline ** No working email address ** noworries 0
    Jul 2006
    Default Adding a IG spa to an IG pool
    Does anybody have any experience adding a IG spa to an existing IG pool?
    I'm a DIY kinda guy--but digging a big hole next to my pool scares me. I'm in socal. If anybody has any advice or any recommendations on who to talk to--I'm all ears!
    Default Re: Adding a IG spa to an IG pool
    You can add a spa to your existing pool.
    Will the spa be built within the pool perimeter?
    Will the spa be built outside of the pool perimeter?
    Will the spa be built partway into the pool?
    Will the spa be raised or at pool level?
    Pool spa combo with same equipment with spa spill over?
    Pool and spa with separate equipment and no spill over?
    Pool and spa with separate eqiupment and spill over?
    Pool and spa with separate eqiupment and water feature from spa wall?
    Jul 2006
    Will the spa be built within the pool perimeter? Didn't consider this an option
    Will the spa be built outside of the pool perimeter? <-- preferred
    Will the spa be built partway into the pool? No
    Will the spa be raised or at pool level? Would like it slightly raised so that I can have a waterfall spillover into the pool
    Pool spa combo with same equipment with spa spill over? Yes, but need to add a heater, a blower, and maybe a boost pump?
    Pool and spa with separate equipment and no spill over? No
    Pool and spa with separate eqiupment and spill over? No
    Pool and spa with separate eqiupment and water feature from spa wall? No
    I just haven't found much info on anybody doing this. I'm considering just buying a AG spa and having it seperate. The only pricing I've heard was in the $30k range--which was really funny!!
    I would imagine I'd probably have to drain the pool to add the spa. The idea of digging a big hole right next to the pool--I'd think there would be cracking issues. That, plus the gas line is on the opposite side of the yard, and would require a lot of work and trenching through concrete to get it over to the pool equipment--makes me think AG prefab would be a lot cheaper and easier.
Closed Thread
  1. Adding cal-hypo to pool
    By kjmelak in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-24-2007, 07:37 AM
  2. Adding Dry Ice to Pool
    By chem geek in forum General Interest
    Last Post: 11-22-2006, 04:32 PM
  3. Adding a return to an AG pool.
    By esalkin in forum In-Ground Pool Construction and Repair
    Last Post: 08-16-2006, 09:39 PM
  4. new ? on adding salt to non-SWG AG pool
    By GraceByDesign in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-31-2006, 09:08 PM
