Brilliant minds think alike!
Sean Assam
e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
Yea, I just have to work on typing fasterOriginally Posted by Poolsean
Mark
The hose comming out of the pool i.e. right below the skimmer basket has some small leaks.Despite the fact a leaky hose should be replaced anyway! Does anyone think replacing the leaky hose would remedy the low pressure problem???
If a suction hose is leaking water, the pump is most likely off. Therefore, with the pump on, it is probably sucking air.....very possibly causing the low filter pressure.
A pressure drop like you're describing should result in noticeable decrease of flow into the pool. If your flow back into the pool seems normal, consider the guage as a source of the fault.
The leaky hose was replaced. The pressure gauge still reads around 2 instead of 8.
There are 2 or 3 big air bubbles at the top of the strainer basket.
Worst of all, the motor ran for 2 minutes then shut off.
What should I try next???
