Thread: Help with raising ph
    ccc is offline ** No working email address ** ccc 0
    Default Help with raising ph
    I have a vinyl pool 22,000 gal Icant get the ph up Ihave put 3 boxes of borax in and still get a 6.8 reading. Clorine is hi and alk is about 110. can anyone help ? please and Thanks
    Attleboro, MA.
    Default Re: Help with raising ph
    What is your actual Total Chlorine reading (Free Chlorine and Combined Chlorine would be better) and CYA?
    I had a problem too raising up my PH and found out that since my CYA was so high (100) it was counting towards my Alkalinity. So I raised my Alk first and then the PH started to rise after adding Borax. Seems though no matter how much I add my pool likes to be right about 7.5 for PH. I also use trichlor pucks which I've read can wreak havoc on PH.
    The following thread talks about how to adjust your Alk if you have high CYA levels.
    http://www.poolforum.com/pf2/showthread.php?t=3581
    gerri is offline Registered+ Thread Analyst gerri 0
    Jul 2006
    Upstate, SC
    Your Alk may be keeping the Ph stable where it's at.. that's a guess from a newbie. One idea I have though, have you pointed your eyeball (jets) straight up to aerate the water? That raised my Ph for me.
    duraleigh Guest
    ccc,
    I'll bet your test only goes as low as 6.8 pH so you were probably much lower to start. Keep adding the borax....one box at a time.....it'll start to move when you get enough in there.
    Alk is fine and your result of "hi" for chlorine is to indeterminate to have an opinion.
  1. Raising PH
    By adayray in forum --cleanup--
    Last Post: 06-29-2013, 08:00 PM
  2. Raising pH level wihout raising Alkalinity
    By JMannWV in forum Dealing with Alkalinity and Calcium
    Last Post: 07-31-2012, 11:28 PM
  3. raising alk
    By CanuckPool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 10-10-2006, 08:56 PM
  4. Raising PH
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-08-2006, 11:50 AM
  5. raising alk?
    By dhale63 in forum Dealing with Alkalinity and Calcium
    Last Post: 05-16-2006, 04:57 PM
