Re: draining pool, when would you really need to?
coryinsocal
...what i was hoping to do, is try to keep up on my own, while my pool guy comes to get the hang of this. is there any reason i shouldn't be going this route? would my adding chlorine while he may be doing something different cause any problems...
Each pool owner is going to have a different level of comfort taking care of their system. The chemical makeup of tap water is different everywhere (FC, CC, Alk, Cal, pH, copper, iron, etc.) and has an impact on your pool chemistry, especially if you live in a hot breezy area and you have to frequently add makeup water (we evaporate 10 mm water level per day). The ONLY way to be sure of what chemicals are added to your pool is to be the ONLY one to add them. The BBB methods described within this forum are relatively straightforward, but may not be practiced by your contractor. Why not get yourself a good test kit (PS234 works very well for me--I disposed of the simple Pentair 78HR kit supplied with my pool), spend a little time learning from users of this forum, and learn by doing? I think you'll find yourself to be quite capable of maintaining a safe, clean, fun pool and you'll save a bit of cash as well.
--Rx
15,000 gal IG plaster/gunite pool & spa w/gas heater, 60 ft2 DE filter
