Thread: help with chlorine
    ccc is offline ** No working email address ** ccc 0
    Default help with chlorine
    I cant get chlorine to regester Ph is 6.9 I put boraxo in to bring it up. Alk is at about 80. Iuse 6way tester from Walmart
    CToon is offline Registered+ Thread Analyst CToon 0
    Elkins Park,Pa
    Default Re: help with chlorine
    For the 5 way kit from walmart , if you fill the test cylinder up to the line and added 5 drops and it didnt register , you need to add chlorine.
    Look for MWsmiths Bleach Calculator . It will tell you how much bleach you need for your size pool
    fcfrey is offline ** No working email address ** Thread Analyst fcfrey 0
    Central PA USA
    I hope you meant Borax (20 mule team) and NOT Boraxo (hand soap).
    Quote Originally Posted by ccc
    I hope you didn't use boraxo....that is a hand soap. You need to use Borax (20 mule team in the green box)
    Have you put any chlorine into the water? How much? HOwmany gallons is your pool?
    Please post a complete set of test results, how many gallons your pool is, and whether it is vinyl, fiberglass, or plaster.
    gerri is offline Registered+ Thread Analyst gerri 0
    Jul 2006
    Upstate, SC
    I think the 6 way is the test strip. I have some of those from WalMart but since I found this site I upgraded to the drops kit. It's amazing how different your readings are with the strip and drops. I won't trust a strip test again.
  1. Chlorine tabs vs chlorine bleach generic
    By Cahoonh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-13-2013, 09:28 AM
  2. High Chlorine Level with no Chlorine Added in 6 weeks
    By morechoff in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 07:52 AM
  3. Free Chlorine vs. Total Chlorine adjusting
    By Truckman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2006, 05:00 PM
  4. alternatives to chlorine/non-chlorine pool maint
    By leewest in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-04-2006, 10:53 PM
