Results 1 to 10 of 16
Thread: before i kill myself with stabilizer
    Default Re: before i kill myself with stabilizer
    Quote Originally Posted by tenax
    i bought some today..recently stopped using bucks and went with regular bleach but with a lot of heat lately, burning through it pretty good so i broke open my wallet and bought some granular stabilizer....am i correct in reading somewhere that to avoid noxious gas to "add the chemical to water", NOT "add water to the chemical".
    or was it the other way around.
    T
    I think you are referring to 'strong' acids like muriatic, i.e. hydrochloric, (and sulfuric, nitric, etc). In these cases you ALWAY add the acid (already a liquid) to water and not the other way around or it can boil violenlty and splatter all over the place! Cyanuric acid, while an acid, is what is known chemically as a 'weak' acid', much like citric acid, ascorbic acid (vitamin c), or acetylsalicylic acid (asprin) .
    must be..i think i tasted some while i was smoking a cigarette (didn't wash hands first..LOL)
    ps- talk about strong? i worked for pepsi for 2 summers many moons ago and the concentrate for pepsi and hires root beer is so strong that it is like soft fudge. came in a 1 gallon "wine box" type thing..and you add 1 gallon of the concentrate to 10,000 gallons of water..(then 20-88 lb bags of sugar!) the concentrate is so strong that i saw a guy burn a hole in his tongue when he put a bit of the concentrate on it.
    needless to say, i can't drink pepsi ever since. the smell makes me gag
  1. Pool Pump that will not kill itself
    By tan21sec2 in forum Pool Equipment & Operations
    Last Post: 08-13-2012, 05:56 PM
  2. Green walls - just can't kill it all
    By PoolFinger in forum Dealing with Algae & Slime
    Last Post: 06-25-2011, 09:05 PM
  3. Using DE to kill ants question
    By Mom2Czars in forum Pools, Pets and Creepy Critters
    Last Post: 10-15-2006, 03:31 PM
  4. Need to kill ants
    By jenpen400 in forum Pools, Pets and Creepy Critters
    Last Post: 09-06-2006, 11:01 AM
  5. does shocking kill algae ?
    By lenhorn in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-31-2006, 09:07 PM
