Results 1 to 10 of 10
Thread: Questions about leveling
    jenpen400 Guest
    Default Re: Questions about leveling
    We used a water level on our 24ft pool. It is a simple accurate low tech way to make things very level. BTW we also used the level to install the drain field for our septic and we installed a 30 x 40 metal building, Husband hand dug the foundation framed it and set all the anchor bolts. All we used was a tape measure string and a water level it came out perfect!
    You really can't get anymore accurate that a water level, yes it's basic, but it's correct - always! A transum can still be out of whack - lots of user error can happen unless you know how to use one well.
    Default Leveling update
    Thanks for everyone's help with the leveling info.
    Here is the update: I QUIT!!!
    We are in Middle Tennessee and I have hard packed red clay. After spending 7 hours and getting about 3 sq ft. leveled, I relized we could not do this part ourselves. A guy with a skid steerer will be here in the morning. He is a friend of a friend, has done several pool installs and is giving us a REALLY good rate.
    I'm looking forward to being done with dirt.
    Sounds like way to much fun Trimom, hope things go better with the heavy machinery.
    So right Matt, nothing is more accurate than water itself. I have seen one of those tubes used once but never could really get a hold of the idea for my purpose. Something about teaching an old dog new tricks.
    Later, Dennis
    Trimom - had you mentioned clay I would have told you to throw in the towel, I also got a skidsteer in to level mine - same reason, I'd still be at it if I didn't 3 yrs later!
    Sometimes, it's just worth it to out-source the work.
  1. Need help leveling land
    By Johnny13334 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-31-2013, 06:37 AM
  2. need help leveling
    By tleigh0212 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-10-2011, 07:09 PM
  3. leveling for AGP
    By link6 in forum Above-Ground Pool Construction & Repair
    Last Post: 04-30-2011, 11:04 AM
  4. leveling
    By badutahboy in forum Above-Ground Pool Construction & Repair
    Last Post: 03-30-2007, 01:18 PM
  5. Leveling the sand
    By rick18' in forum Above-Ground Pool Construction & Repair
    Last Post: 06-16-2006, 12:47 AM
