Do I need calcium in a fiberglass pool? I've been studying water chemistry to be prepared for my upcoming new IG fiberglass and can't really answer this question.
Donnie
Donnie
You need to keep a CH level to prevent calcium from leeching out of the plaster. Based on that assumption, a fiberglass pool should not need to calcium. I may be wrong but that is my feeling. Now if you have a heater I think that you do need to maintain your CH level.
Outside of Philadelphia, PA
18' x 40' IG - 22K gallons
Sylvan Gunite Pool (1979)
Plaster re-done (1997)
The only other good reason to keep calcium in a F/G pool is if the manufacturer requires it for the warranty--you don't want to give them ANY excuse to back out of honoring it if you need it.
Ahhhh I didn't even think of something like that. Good point Carl.
I just checked with the heater mfg and it says to keep TA @ 120-150 which is a little higher than recommended on this site and to adjust calcium to 200 300. Thanks for the tip. I never considered the heater requiring calcium. Just trying to sort all of this stuff out before hand. Any thoughts on the higher TA?
Donnie
TA of 120-150 should be fine.
Thanks! Now if I can just get over the stress of all this. Maybe a beer will help.............................................. .................................................. .................................................. .................................................. .............................Yep!
Donnie
You will love your fiberglass pool! I run mine with calcium of about 150. I find using the bleach, baking soda, and borax combination works best for my pool. If you have any metals, be sure to put in a sequestering agent - fiberglass pools tend to stain if there are any metals in the water. A sequestering agent will hold the metals in suspension which will avoid pool staining. Other than that you won't need anything else.
Northeast PA
