Help please... Marie, I wish I knew your number...and I'm sure you're glad right now that i don't have it..![]()
Anyway, I put my pump on recirculate after dropping the ascorbic acid treatment in and my pump is losing water out the drain hose, where water comes out when I backwash! I was losing a lot of water so I have the hose in the skimmer now. I put some metal treat in too.
I turned the pump off and came in to see if I can get some help as to what to do. My pump also has a setting that says "close" - would that work?
I can see where I dropped the AA down the sides of the pool.. it does work like magic. What a time to discover a problem with my filter!!!!!!![]()
