Closed Thread
Thread: When are cup anchors installed?
    Dec 2005
    Rancho Murieta, CA, USA.
    Default When are cup anchors installed?
    When are Cup anchors installed in the construction of the pool.
    My gunite guys are telling me the plaster guys will do it. Is this true? Do the gunite guys need to do anything special?
    Default Re: When are cup anchors installed?
    What are those used for? The rope to separate deep from shallow?
    GutierrezPlastering Guest
    the 14-507 are the typical cup anchors installed, they look nicer and don't stand out at apose to those others that you have up there, The plaster guys can put them in, just make sure that there are holes where they will be installed. also that they are infront of one another, and atleast 1 1/2 inch underneath your tile line, also when installed to make sure that they will be flush with the plaster, almost a even line with the tile for a perfect,smooth fit.
    Dec 2005
    Quote Originally Posted by Jeffski
    You can use them for that. I plan on securing a thermometer to one of them.
Closed Thread
  1. Getting new pool installed
    By flubby in forum In-Ground Pool Construction and Repair
    Last Post: 06-10-2011, 11:39 AM
  2. Removing Damaged Brass Concrete Deck Anchors
    By roddiaz1 in forum In-Ground Pool Construction and Repair
    Last Post: 10-17-2010, 01:53 PM
  3. Installing anchors for winter cover ?
    By cleancloths in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-24-2007, 09:41 PM
  4. ladder: anchors how high?
    By us7sail in forum In-Ground Pool Construction and Repair
    Last Post: 08-23-2006, 06:00 PM
  5. Installed my new ...
    By Phillbo in forum In-Ground Pool Construction and Repair
    Last Post: 06-09-2006, 07:31 PM
