Results 1 to 10 of 22
Thread: How do you calculate head?
    mas985's Avatar
    Pleasanton, CA
    Default Re: How do you calculate head?
    Well, if it helps any, I was running my pump for a 1/2 turnover during the winter and now I am runing it a 1 1/2 turnovers per day and the water is crystal clear. However, my bather load is light.
    One thing you might want to try, is to lower the run time gradually. Drop a few hours each day until you hit 12 hours so you can monitor any changes.
    Mark
    IL.
    I may do that. I think there's an intermatic timer at my in-laws that they use for Christmas lights, I'll see if I can borrow it and do some playing around.
    We're coming into the hottest weather, so it should be a good test
  1. AGP and 1hp Pump... Calculate Turnover?
    By Solarius99 in forum Pool Equipment & Operations
    Last Post: 06-20-2011, 08:53 PM
  2. Formula to calculate expected Pool Water Temperature???
    By TheG$ in forum Pool Equipment & Operations
    Last Post: 05-11-2007, 06:18 PM
  3. New Vac head
    By Macrosill in forum Above-Ground Pool Construction & Repair
    Last Post: 07-19-2006, 07:20 PM
  4. How to calculate the size of my pool
    By Sunny32504 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-09-2006, 10:16 PM
  5. How to Calculate Feet of Head...???
    By Sherra in forum Pool Equipment & Operations
    Last Post: 04-12-2006, 03:58 PM
