Results 1 to 10 of 13
Thread: an idea i'm going to try for spring startup and chlorine generators
    Default an idea i'm going to try for spring startup and chlorine generators
    i ran this idea by poolsean with autopilot last night re: season startup and shutdown at end of season for that matter. while it was specifically re: the autopilot, i'm sure it would be easy to adapt for other chlorine generators. my concern as i get into this is the pool is pretty dirty at start of season with decayed leaves, algae over the winter. rather than have the chlorine generator go through all that before i need it to generate chlorine, i'm going to get some pipe and fittings and build a "mock manifold" that i will simply put in line on the system instead of the chlorinator until the pool is clean enough to fire the generator up. it seems to me that having the chlorinator in line at seasonal startup is unnecessary wear and tear on the autopilot system at that point. ran it by sean and he thought it was a good idea.
    mas985's Avatar
    Pleasanton, CA
    Default Re: an idea i'm going to try for spring startup and chlorine generators
    If the SWG is after the filter, why not just turn it off instead of bypassing it?The water itself should be relatively clean after the filter and not degrade the cell unless the PH is real low or high. From what I understand, the life of cell is determined primarily by the amount of time it is on. Just use bleach for start-up and then when the pool is under control, switch on the cell.
    Mark
    i was thinking there would still end up being a bunch of crap flowing through the cell even if turned off unless the manifold is valved to bypass? also, i don't see the need or desire in freezing winter conditions to have the manifold outside..
    that's my thinking anyway
    Saint Cloud, FL
    You can also put a golfball in the screen before the cell, shutting off the cell and flow through it.
    Pat
    ah yes..i forgot seeing that option on a diagram (i don't have the unit yet) thanks..i may look at that option.
    Ft Lauderdale, Fl
    GOLF BALL ONLY WITH THE MANIFOLD THAT HAS 1.5" PIPES, NOT FOR THE 2" MANIFOLD ASSEMBLIES!!!!!!!!
    The golf ball will most definately get pushed into the tri-sensor and break it.
    Now, if you want to use the plastic bag trick, you can do that. Just tuck the plastic in so that it's not sticking out and causing a leak.
    Sean Assam
    e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
    duraleigh Guest
    tenax: (to the kids in the pool playing near the return) "Fore!!"
    kids in the pool: "ouch!"
    (Okay, no more scotch for me!)
    ouch ok..so i'm clear, i have 1.5 inch piping..but the manifold itself will be 2 inches with the autopilot soft touch, i'm assuming? if correct, you're saying don't use a golf ball period unless everything is 1.5 inch (i thought the autopilots all had 2 inch piping?)
    thanks
    Ft Lauderdale, Fl
    YES....and NO. We do have a 2" manifold assembly but am going back to the main loop to 1.5". The inlet and outlet tees will still be 2"
    Sean Assam
    could swore i saw a picture somewhere showing positioning of the golf ball cause i'm not quite clear..sorry..my biorythms are off this time of night..or will it be like computers and make sense completely once i have the unit..i would hate to have to return saying cause of failure was a golf fall in the system
    hey..better safe then sorry!
  1. spring startup mutivalve question
    By Txboynjgirl in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-08-2013, 04:41 PM
  2. spring startup
    By jarsch in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-09-2012, 11:05 PM
  3. Spring startup advice
    By NBWS6 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 03-29-2009, 05:43 PM
  4. Pumped locked up on spring startup?
    By rtpatter in forum Pool Equipment & Operations
    Last Post: 03-26-2007, 04:57 PM
  5. Spring Startup from empty
    By jdcrysler in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-01-2006, 12:08 AM
