Closed Thread
Results 1 to 10 of 13
Thread: Caulk between deck and coping?
    bhelme's Avatar
    bhelme is offline ** No working email address ** bhelme 0
    Baltimore, MD
    Default Caulk between deck and coping?
    My pool "chemical seller" company says I need to replace the closed cell foam between the deck and coping with caulk. My builder said nothing about that. Do I need to do it?
    duraleigh Guest
    Default
    Hi, Brian,
    Give me a little more info. Be very specific where it's located. How much of it? Does it extend all the way around? What surface do you see there now? How wide is the gap.
    Most expansion joints (I'm sure that's what this is) are a combination of closed cell foam sealed on the visible surface with caulk. I'm a little confused when you say "replaced with"
    Dave S.
    bhelme's Avatar
    Baltimore, MD
    Default
    Wow, you're hitting all my questions today aren't you?! Thanks.
    The foam runs the entire perimeter of the pool between the coping and the deck, "approx. 115 linear feet" (chemical seller's estimate). The gap is about 1/2" and the foam is about 3/8". I know when the deck was put in that the foam is about 4-6" high (whatever thickness the deck is). Currently the foam is level with the top of the deck and coping, not recessed.
    All the written quote says is "caulk the expansion joint", not what exactly they'll do. $684 sounds like a lot if all they're doing is capping off the top. Heck, even if I have to buy some specialty caulk and cut away some of the foam to get a decent layer I ought to be able to do it for a lot less. Do you think it's a DIY project?
    duraleigh Guest
    Default
    Hi, again,Brian,
    Yes, it's a DIY. That said, it's amazingly tedious and you must be VERY careful working with polyurethane caulk but it's actually quite rewarding and you can do an even better job than they because it's your pool.
    1. You must "scrape" out the foam down about 1/4" at least and 1/2" is better. Resulting channel should be as deep as it is wide.
    2. Next you need to somehow seal the space between the foam and the decking (or coping) if the foam doesn't reach from side to side. That could be tough to do. I'm thinking of finding some type of cheap plastic trim from home depot you could wedge in between the foam and the coping to get a tight fit. (you said gap is 1/2 and foam only 3/8, right)
    3. You're ready to caulk. Polyurethane is the most durable you can use but it's not very forgiving....here's what I did. Carefully fill the channel just slightly overfull with a caulk gun. Be careful not to let much get out of the channel, it a bear to clean. (keep a rag with MEK solvent handy). Once you've caulked as carefully as you can, drag a 1" putty knife down the seam applying slight downward pressure. The caulk should compress into the channel slightly and then bulge the tiniest bit after the putty knife passes over it.
    That's it! That little rounded bulge will flatten virtually level as the caulk dries.....be aware, 24 hours before you can touch it and days before it's completely cured. The result, however, is a magnificently durable, waterproof seal that will last for years.
    I used a product called Vulkem 911 by Tremco. Found it at an industrial supply house for about $3.15 per tube, I think. It comes in lots of colors so you can match it with surroundings pretty well.
    You might try a few feet and see if you want to tackle it. I had much less to do than you and it was quite time consuming. If you pay to have it done, I'd be pretty adamant about polyurethane caulk. It would be mighty easy to put acrylic in there and walk away. I don't believe it will hold up in that harsh environment. Let us know if you tackle it!!
    Kelly, Ted, or one of the other pro builders may come along and offer a less labor intensive solution if you can be patient......they don't check in as often
    Dave S.
    Lenny is offline Lifetime Member Thread Analyst Lenny 0
    Wilmington, Delaware
    Default
    Dave is right on as always.
    I have to do the same thing. I was suprised that my builder did not take care of this but it sounds like that's the norm. My install was done too late in the year to caulk. I tried but it was too cold and the caulk wouldn't flow well.
    I'll look for Vulkem. I picked up several varieties from Home Depot and Lowe's and I'll try them out soon to see what works best. There are a few types that are meant for concrete expansion joints and they're supposed to look like concrete when they cure.
    Default
    I did the same thing last season. The estimate got was $6 a foot so the $600 price you were quoted seem right.
    I used this sonnebone NP1 caulk and the backer rod. There is also directions at the bottom of the page.
    http://www.poolcenter.com/service_su...g_supplies.htm
    Don't order from this company if you decide on going with Sonneborn, though. If you find a dealer, you can get a 30 case of caulk for $100 and the backer rod is about $12 for 120 feet.
    I would use the backer rod, It is just easier.
    I used duct tape and put it on both edges of the gap around the entire perimeter of the pool, to keep the edges clean. then just caulk and remove the tape once the caulk is in place and shaped.
    Also color is important. White is very unforgiving if you are a little sloppy about your work. It will look like crap it you are not very neat. I used a gray color to match the cement and it blends very well.
    I would do a practice section to get the hang of it. When it dries, you can pull it out with a knife if you don't like it.
    This job was pretty labor intensive, all told between scraping out the foam, putting in the backer rod preping and caulking, I bet it took me 10 hours.
Closed Thread
  1. Replacing deck & coping on a vinyl liner pool
    By sampeterson18 in forum In-Ground Pool Construction and Repair
    Last Post: 06-22-2014, 10:22 PM
  2. Pool Deck Caulk
    By rck26186 in forum In-Ground Pool Construction and Repair
    Last Post: 04-20-2013, 10:04 AM
  3. installing new deck and coping
    By ArtCan in forum In-Ground Pool Construction and Repair
    Last Post: 04-17-2012, 11:49 PM
  4. Identifying the grout/caulk between brick patio and coping
    By Ian Rob in forum In-Ground Pool Construction and Repair
    Last Post: 06-23-2010, 09:13 PM
  5. Type of caulk between coping and deck?
    By billhev in forum In-Ground Pool Construction and Repair
    Last Post: 05-26-2008, 10:16 AM
