First, you should apply glue to both of the mating pieces. Push the joint together and twist some. Usually a 1/4 twist is OK. I twist back and forth a few times. Don't skimp on the glue. Note that for some reason, you push the joint together and before the glue sets the joint seems to want to separate. Keep pressure on it to keep it seated until the glue sets. Usually about one minute should be OK. Schedule-40 is the typical white pipe/fittings. The grey stuff is usually sched-80 but the same glue is used. I used the same glue (Oatey green can) on the S-80 fittings to S-40 pipe for my heater when I had it. The sched-40 pipe and fittings are used for pressure applications and the unions, 90's, etc have about a 1.25" seating depth for the pipe. From what you describe I'm betting you just didn't use enough glue. Hope this helps. At least the stuff is cheap when you goof.
