Results 1 to 8 of 8
Thread: Aquarite vs Pentair Intellichlor IC40. For Intellitouch system
    Default Re: Aquarite vs Pentair Intellichlor IC40. For Intellitouch system
    I went with the AquaRite for the reasons you cited. Lower first cost, lower cell replacement cost and the ability to work w/my IntelliTouch controller. I like Pentair products in general but didn’t see the benefit to having the electronics in the cell. You end up paying for that every time a cell needs replacement.
    I do find that on occasion the AquaRite will stop talking with the IntelliTouch and I have to turn off and reinitialize the SWG interface at the IntelliTouch indoor control panel. All the SWG status characteristics look OK but in order to raise or lower the chlorine production percentage I have to go through the above process.
    So you only have to reboot it if you want to raise or lower chlorine production percentages? How exactly do you reboot it?
    I find that disabling then re-enabling the SWG interface at the IntelliTouch indoor panel is all that is required to resolve the issue. I haven’t devoted much time to troubleshooting since it is a relatively minor annoyance and it doesn’t happen all of the time. I really only noticed it recently as my chlorine requirements have been rising with the higher summer temperatures which has required me to tweak my chlorine production upward.
    Orlando, Florida, USA.
    I use the IntelliChlor. I got the IC40 with power pack for $775. I just looked on e-bay. There is a new IC40 with power for $499 (the average seems to be around $700). I don't know what the other brands are selling for.
    Whatever you go with, get the largest size cell. That way you can run the cell at a lower output and it will last longer.
    Good Luck
  1. Field calibration for Intellichlor IC40 SWG
    By Azsnook in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-24-2012, 08:48 PM
  2. IntelliChlor IC40 Issues
    By dchango in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-23-2011, 10:37 AM
  3. Adjusting Pentair Intellichlor IC40
    By newpoolguy in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-07-2011, 10:22 PM
  4. Using Intellitouch with Intellichlor
    By hulla in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 10-24-2006, 01:43 PM
  5. In floor Cleaning system with Intellichlor IC40
    By Katybug92 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-15-2006, 05:47 PM
