Thread: Sand filter and flow...
    Default Sand filter and flow...
    Hi All,
    My sand filter is rated at 60gpm while my new pump will flow 70gpm. Is that OK or will I have problems? I am guessing I should be OK but it's just a guess.
    Thanks,
    Joe
    duraleigh Guest
    Default Re: Sand filter and flow...
    Hi, Joe,
    Surprised no one else has responded....generally, the filter gpm should be more than the pump gpm. I doubt you'll have any problems but if you wanted to "match" them a little better, you could restrict the flow a little.
    That's best done by throttling down one of your shut-off valves on the return side. Filter psi will go up but your gpm will go down and you'll use a little less electricity. (How am I doin', Al?) (inside joke)
    You could then roughly calculate your actual flow by using mas985's simplified TDH calc.....filter psi * 3.2 and use the pump curve to calc your flow. If I have conveyed that info somewhat obscurely, post back and I'll try to say it a little better.
    Tennessee
    duraleigh
    Where can I find the pump chart?
    duraleigh Guest
    Hi, Steve,
    If you don't find it on the pump's documentation, Some manufacturers will post it on their website. If still no luck, my next step would be to call tech support and ask for a copy.
    As a last resort, you could probably get pretty close with a pump curve from another manufacturer if the specs were pretty close to yours.
    OK that sounds great. I will eventually upgrade to a DE filter that can handle 96gpm but funds are a bit tight right now. Between the Dolphin and Poolbuster my wife is tiring of my pool spending habits so I'll have to take it slow.
    Thanks,
    Joe
    Tennessee
    duraleigh
    Thanks I will look in the books in the morning after I get off work. I didnt think of looking there duhh
  1. 2HP Ultra Flow Pump Titan SS DE Filter
    By fasttruck9 in forum Pool Equipment & Operations
    Last Post: 08-24-2012, 11:47 PM
  2. Low flow on intex saltwater/sand system?
    By digitaldoodlebug in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-18-2011, 06:28 PM
  3. DE Filter low flow
    By Chreepo in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-11-2007, 12:29 PM
  4. Sand filter design flow rate question
    By mbaldwin in forum Pool Equipment & Operations
    Last Post: 07-14-2006, 05:42 AM
