Thread: Amount of FC
    Whitby, Ontario, Canada
    Default Amount of FC
    So if the desired amount of FC (free chlorine) is 3ppm, and when you test your FC is less than that, does that mean you should add the correct amout of bleach to bring it back to 3ppm ?
    For example lets say you had the following:
    TC = 3
    FC = 2
    CC =1
    This would suggest that the clorine is busy fighting something as the CC =1. In this case would you add enough bleach to bring the FC back to 3, thereby giving a TC of 4 ? or would you super clorinate, as you know the chlorine is currently fighting something ?
    Default Re: Amount of FC
    You would superchlorinate to complete the fight--but to what level, and what level you should keep your TC at, depends on your CYA level. See Ben's best guess chart at the top of this forum.
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    If your numbers are as you state and you have a CC of 1, then you should bring your FC up to SHOCK levels (depending on your CYA level...see Ben's Best Buess Chart - http://www.poolforum.com/pf2/showthread.php?t=365 ) to get rid of the CC.
    But your math is correct. TC=FC+CC You don't want your CC to get to 1 or higher. If it does then bring your FC up to "shock" levels, which should get rid of the CC.
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
  1. Bleach Dose amount when filling
    By PaPoolNewB in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-31-2012, 12:10 PM
  2. Amount of borax to use to raise pH
    By tcward in forum Pool Chemistry for Intex-type Pools
    Last Post: 05-14-2012, 11:23 AM
  3. Baby Pool Chlorine amount?
    By hoffmans in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-19-2007, 02:43 PM
  4. What amount of CYA is best???
    By mariner09 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-24-2007, 04:28 PM
  5. Amount of Final Draw is Crucial
    By webfeet in forum In-Ground Pool Construction and Repair
    Last Post: 05-19-2007, 09:06 AM
