Quote Originally Posted by Rangeball
I may have screwed up...
I'm wondering if the shock level of TC gave me a false high on PH, and I actually lowered it too much. I did use the chlorine neutralizer before testing PH, but only 1 drop as instructed. Could this be the case?
Yep, never test your pH when the chlorine levels are high. even with chlorine neutalizer you can get a false high reading. If your OTO was brown you were at a VERY high chlorine level!
