Results 11 to 12 of 12
Thread: Do you ever have to replace sand in a sand filter
    duraleigh Guest
    Default Re: Do you ever have to replace sand in a sand filter
    I have awful dirty dark green water even after days of shocking. I too am beginning to think I need to change sand. I usually can just shock and get past this, but it doesn't seem to be working.
    Thanks to all, I did end up changing it, the good advice of the pool center was "when in doubt change the sand".............I seem to be able to clean up now so I guess that really was it!
    I am glad your pool has cleaned up. However, I think it is misleading to Newbies to assume that changing their filtration will fix an algae-ridden pool....it will not.
    Changing the sand, changing the cartridge or putting new DE in your DE filter will not eliminate algae. Newbies would do well not to get that mind set.
    The addition of chlorine at ADEQUATE DOSE LEVELS will do more to clear your pool than any other solution.
    Without test results, none of us here can accurately answer why your pool was green or how it got cleaned up.......nevertheless, I'm glad your methods worked for you. I simply think it's misleading for beginners to chase algae by changing filtration.....that doesn't eliminate the source of the problem....chlorine does that.
    I have to agree with Dave. Chlorine kills algae! The filter will remove the dead algae from the water. It is important to have the filter in good running order for it to do this, however. If you have neglected your filter then breaking it down and getting it back into shape might help it clear the dead stuff out of the pool but it will NOT get rid of an algae prolem.
  1. Sand Filter dumped all the sand in my pool
    By ib_gman in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-15-2012, 01:16 AM
  2. How often shoud I replace sand in sand filter?
    By mikef in forum Pool Equipment & Operations
    Last Post: 07-18-2011, 11:41 PM
  3. Sand Filter Sand amount question
    By kevincad in forum Above-Ground Pool Construction & Repair
    Last Post: 07-04-2008, 09:36 AM
  4. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
  5. Sand Filter from 1982 - replace it?
    By CandyMoss in forum Pool Equipment & Operations
    Last Post: 04-04-2007, 03:00 AM
