Thread: Coverting from Bacqui-hell I mean Bacqucil to Chlorine
    Default Coverting from Bacqui-hell I mean Bacqucil to Chlorine
    Ok...so we have a Inground concrete pool that came with our house we
    bought last summer. Last summer, we moved in beginning of July but didn't
    use the pool at all due to my inability to get a clear pool with BacquiHELL.
    We closed the pool with a substancial amount of green algae in it (hoping
    winter would kill it off).
    This summer, I went to Leslie's Pool company and followed their
    instructions for converting to Chlorine and removing the Bac from our pool.
    My main problem is, we have a ton of dead algae at the bottom of the
    pool left over from multiple algae blooms last summer. I've been vacuuming
    and backwashing out the wazoo but still don't have all the dead algae out of
    the pool yet.
    Question - should I finish cleaning out all the old algae before adding the
    chlorine or "shocking"? The water is a hazy green...I can see the bottom of
    the shallow end..but the dead end is hard to see to the bottom. I have noticed algae starting to regrow on the sides of the pool.
    I do have a tub of the Chlorine pucks but haven't started using them
    yet as I thought the algae would eat up and waste all the chlorine added.
    Mariza
    Default Re: Coverting from Bacqui-hell I mean Bacqucil to Chlorine
    sorry..the rest of it
    Inground plaster pool...not sure of the exact gallons...I'm estimating
    22,000 gallons. 500 square feet in kidney shape is what the pool
    manufacturer told me.
    DE filter
    and yes, the water is a hazy green...
    You need to get chlorine in the pool ASAP before you grow another large crop of algae. The dead algae on the bottom isn't going to bother it--continue to vaccuum it to waste, and it will eventually go away (keep your filter on 24/7, too). Need to know numbers for Cl, CYA, pH, and TA in order to tell you how high the Cl needs to be to kill the current bloom, but you do definitely need to shock the pool.
    our latest numbers were:
    FC <.5ppm
    TC <.5ppm
    PH 7.5
    Alk 80
    How do I test for CYA?
    The WalMart 5-way kit that sells for around $15 has a CYA test in it, or you could take it to a pool store to have it tested but either way you need to do it quickly because algae is growing in your pool as we speak..............
  1. Dubosity's Thread: Lost in Cloudiness/Mustard Algae Hell
    By Dubosity in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-10-2011, 07:59 PM
  2. Pool Hell
    By ehorn in forum In-Ground Pool Construction and Repair
    Last Post: 08-09-2006, 01:38 AM
  3. Looking for a give-it-hell pole
    By Unabomber007 in forum Pool Equipment & Operations
    Last Post: 08-01-2006, 11:06 AM
  4. New to Chlorine, was in baquacil hell, any advice please
    By coadysmom in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-27-2006, 03:06 PM
  5. Pool Hell
    By jimmurphy24 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-24-2006, 12:52 PM
